ricoh print quality
harry tambo
Re: ricoh print quality
Post by harry tambo »
hi,i,m using the e3300n ricoh,sublimating text onto metal.results are faint black,any suggestions to getting a better print?turned heat press down to 190 and 60 secs sub time,however still paper sticks to metal and the print is black ,but quite faint still.any suggestions?:mad:
Go down to 170 - 175 degrees and 50 seconds. Blacks go off to brown and blurred when you are too hot for too long with ricoh inks.
John G
Post by John G »
Are you using sublimation Ink - (sublijet - R gel ink)
Are you using the powerdriver or if a mac a profile.
What paper are you using and where from
What metal are you using and where from
As much info as possible and it will help with your replies.
harry tambo
thanks mate...
harry tambo
thanks john,sublijet,china paper from ebay,coted metal from xpress,just corel windows 7,not shire on the driver??
John G
Post by John G »
Well, along with your timings, that could be a problem. You need to be using either the powerdriver or a profile.
harry tambo;41992 wrote:thanks john,sublijet,china paper from ebay,coted metal from xpress,just corel windows 7,not shire on the driver??
Make sure you use PowerDriver which is available as a free download from here...
http://www.sawgrasseurope.com/technical ... sublijet-r
Martin cull
Post by Martin cull »
I never did work out why.... But if I printed the same eps file from illustrator and Corel draw, the illustrator version would give a far better result on the finished product... This was on my old Ricoh GX7000
John G
Post by John G »
Maybe the profile/powerdriver wasn't set up properly in coreldraw
