Colour Problems Printing to Flock Using Robo Master - ICM Profile Problem?
mysticalvibes
Re: Colour Problems Printing to Flock Using Robo Master - ICM Profile Problem?
Hello, I've recently started to use my craft robo for cutting subliflock. The problem is that when printing logos etc via the Robo Master software the colours from my printer aren't accurate. I think the problem might be with the printers ICM profile. I normally use photoshop which gives me the option to change ICM profiles, but in the "Robo Master" I cant seem to find anyway to change it. I'm using an Epson B40W printer with genuine artainium inks. I need to use robo master software as its all I have that can read and cut around logos using registration marks. Any help would be greatly appreciated.
Many Thanks
Davy
Many Thanks
Davy
We recommend you cut the shape first, print from PhotoShop and press onto the cut piece.
Robo Master doesn't use profiles, you will need to cut from photoshop ( presuming you can )mysticalvibes;44106 wrote:Hello, I've recently started to use my craft robo for cutting subliflock. The problem is that when printing logos etc via the Robo Master software the colours from my printer aren't accurate. I think the problem might be with the printers ICM profile. I normally use photoshop which gives me the option to change ICM profiles, but in the "Robo Master" I cant seem to find anyway to change it. I'm using an Epson B40W printer with genuine artainium inks. I need to use robo master software as its all I have that can read and cut around logos using registration marks. Any help would be greatly appreciated.
Many Thanks
Davy
I'm more curious how you cut the flock as I am led to believe ( and always have) cut it from the underside of the flock which you can't print on ??
Print it from photoshop with reg marks. Press it to flock then cut it. This is how i usero do that.
How does ROBO Master then know where the image is on the printed flock? It doesn't, so how can this work? Do you use the ROBO Paul?Paul;44112 wrote:Print it from photoshop with reg marks. Press it to flock then cut it. This is how i usero do that.
Yes, cut the shape out from ROBO Master (in reverse, trough the back) and then print the image via PhotoShop. Lay image over cut piece of flock, press and hey presto!accdave;44111 wrote:I'm more curious how you cut the flock as I am led to believe ( and always have) cut it from the underside of the flock which you can't print on ??
I still haven't got the beeping thing to cut a true circle yet out of subli flock yet, Robo or Cameo. Don't start me on the advanced stuffbms;44118 wrote:Yes, cut the shape out from ROBO Master (in reverse, trough the back) and then print the image via PhotoShop. Lay image over cut piece of flock, press and hey presto!
No iam not any more but i useto had it. Now i have a big boy here sono need for tiny cr. I prepered image in robo software with reg marks. They where graphics with outlines ready for cutting. Then i exporthem to file suitable for photoshop and print it from there. This way i had file with great colors and file with all info neede for cutting. Do you question my knowlage martin???
I was asking if you used the ROBO that was all as I thought you had a bigger machine.Paul;44121 wrote:No iam not any more but i useto had it. Now i have a big boy here sono need for tiny cr. I prepered image in robo software with reg marks. They where graphics with outlines ready for cutting. Then i exporthem to file suitable for photoshop and print it from there. This way i had file with great colors and file with all info neede for cutting. Do you question my knowlage martin???
mysticalvibes
Hi guys, Thanks for all your help. Tried cutting the outline using the craft robo but must need a new blade as it only cut through the backing sheet! Had to cut it again with a craft knife. Getting there slowly but surely.
Davy
Davy
