i have just got some dark and light transfer paper from yolo.
what inks should i use i know they should be pigment, but any particular make will the cheaper refills work?
inks for heat transfer paper
- mrs maggot
Re: inks for heat transfer paper
nip onto the yolo page on here, there was a discussion on their papers and what inks to use
gavtheoldskater
i've been using some very basic dye ink and really having no problems, however i am about to change over to a better grade pigment ink for what will apparently be better UV resistance and longevity. also i can then get an ICC (must PM you paul about the two i need) as i'll be with consistent ink.
To be honest you biger problem then UV is washing mashine. Ink will be washed off quicker then uv menage to fade your prints. So i would concentrate on better paper too
