Is this suitable
Charlie_
Re: Is this suitable
Post by Charlie_ »
Its me again, is this suitable for using with heat presses/
http://www.ebay.co.uk/itm/Gasket-Silico ... 3f15da03a5
WorthDoingRight
Post by WorthDoingRight »
It would be but not much use really only being 13cm x 13 cm. I have bought this http://www.ebay.co.uk/itm/X-Large-Silic ... 8bb504dbc1 before.
Charlie_
Post by Charlie_ »
Teach me not to look right was reading it as cm not mm grrrrr
Thanks for the other link though.
I use this same silicon as WorthDoingRight and it works fantastic. for mugs, slates and other bits. also is huuuugeeeeee!
Charlie_
Post by Charlie_ »
Will get some of that then cherrs to you both for your help..
frazzle
Post by frazzle »
Being new to the game what would you use it for?
Craig
Post by Craig »
I also use this on my heat press and it is a good size aswell
WorthDoingRight
frazzle;54681 wrote:Being new to the game what would you use it for?
Silicon sheets are often used to help make sure you have even pressure over a slightly uneven surface when sublimating. We also often use Teflon sheets and Baking parchment/Greaseproof paper for some jobs.
Hi Paul
Why would you use silicon on mugs mate?
S>
Coz some mugs are smaller :-)
