Ricoh GX7000 not powering up
Re: Ricoh GX7000 not powering up
Kaz;49660 wrote:Hi guys, long time no see :)
My Ricoh isn't powering up, well, the lights flash and then go off again. From doing a bit of research, it would appear that it's a common problem with this printer when used with sawgrass inks, somehow manages to knacker the power supply :(
Does anyone know where I can get replacement parts for it, apart from from the states?
Also, I've had it for just over 2 years, and not used it for about a year since we moved house, but research is showing some conking out after just a few months of seldom use aswell.
Do you think it would be covered under SoGA and is it worth pursuing it down that route?
Any suggestions welcome
Have sent you a pm...
Kaz
Post by Kaz »
Thanks ever so much Martin
Annabelle
Post by Annabelle »
I have the same problem, power on, led's flashing power of. What kind of mystery did Martin??? Please help me, Want to keep my GX7000 alife!!!
Users browsing this forum: Amazon [Bot], Google [Bot] and 1 guest
