bigj2552;51414 wrote:the cleaning solution....is it 100ml for each ink cart i need to buy ?
I have both giant cartridges and regular size ones. The regular size ones (
https://www.printercartridges.net/print ... ts_id=1284) hold 20ml each (30ml in the black), so 100ml does just fine for all four. You may need more if you only have the giant cartridges. You'll only use a fraction of the 100ml when flushing, so you'll have plenty left for next time (that's why I have four regular refill cartridges just for cleaning fluid).
bigj2552;51414 wrote:yep, think i will to since you pointed that out ..thanks for link bud
I noticed the expensive City Ink ones call their pigment ink "heat transfer pigment". I don't honestly know the difference, but if you want to use the inks for heat transfers, it may be worth considering. I'm just using mine for regular office printing and photos. I may try transfers later, but it's by no means a decision-maker for me.
