Hello from GR
Re: Hello from GR
Ok i got it, as an alternative to sublimation on the rock slates would this do any good? laser transfer on hard surfaces it says!bms;53790 wrote:Welcome to the forumYou're going to need a sublimation printer if you want to print onto the slates. The current A4 supported Ricoh is the SG3110.
Re: Hello from GR
Laser prints stick to the surface and the rock slates have white sublimation coating on the feathered edges of the product. With sublimation the inks gas off the paper onto the product so you get a great effect of colour transfer in this feathered edge - that wouldn't happen with laser transfer as it would just stick to the flat surface.pentraks;53944 wrote:Ok i got it, as an alternative to sublimation on the rock slates would this do any good? laser transfer on hard surfaces it says!
