Printed teapots?
Re: Printed teapots?
Does anyone know or know of anyone that does printed teapots?
I have an enquiry for about 10 - not a lot for now and unsure if it will develop into bigger orders or not.
Adam
Adam
- WorthDoingRight
Well as teapots are not often put in the dishwasher and I imagine often just swilled out you might be able to use one of the laser printable water slide materials to decorate them?
Yeah - I was thinking about that as I typed it out, maybe an ideaWorthDoingRight;54665 wrote:Well as teapots are not often put in the dishwasher and I imagine often just swilled out you might be able to use one of the laser printable water slide materials to decorate them?
many thanks
Adam, don't know if this would help you out but, could be your answer http://www.youtube.com/watch?v=fkJxFveQU8M
Ian M;54676 wrote:Adam, don't know if this would help you out but, could be your answer http://www.youtube.com/watch?v=fkJxFveQU8M
Thanks Ian - may be just what I need ....................... and can I just say, your voice on the video is a little 'higher pitched' than what I first imagined
- WorthDoingRight
I watched that video and thought what a great idea - that was until you had to use sellotape to remove a layer and I remembered that I can never find sellotape in this house so will have to shelve the idea lol
TMT does a water slide decal that is cheaper if you need a box of 50 and does not need laminating or peeling - however not so sure how long lasting it is.
Yeah but with TMT you also need a laser printer as far as I believe - got enough (and had enough of) printers at the momentWorthDoingRight;54691 wrote:TMT does a water slide decal that is cheaper if you need a box of 50 and does not need laminating or peeling - however not so sure how long lasting it is.
Your more than welcome Adam...................I've got a cold mateAdamB;54688 wrote:Thanks Ian - may be just what I need ....................... and can I just say, your voice on the video is a little 'higher pitched' than what I first imagined
