Need an icc profile creating please
WorthDoingRight
Re: Need an icc profile creating please
Post by WorthDoingRight »
Well you really have a couple of choices around this mark. You have the X-rite Colormunki Photo and the Colorvision Spyder Print. Both of these do ICC profiles for printouts.
Andrew;54830 wrote:What profiling devices are best for around the £300 mark?
colourMunki will be your best shot. accurate enough but you will be doing loads of profile updates... which is good tho :)
JSR
Post by JSR »
Very few people are likely to have more than one profiling device, so that question is only ever going to get the answer "I've got this one, so I think it's the best".
I'd suspect that all the ones around £300 will produce similar results, it just comes down to how easy they are to use and you'll discover that by reading reviews. £300 is "entry level" price when it comes to printer profilers.
I use the ColorMunki myself. If money was no object, I'd buy whatever Paul's got, but the ColorMunki does a good job.
JSR;55028 wrote:Very few people are likely to have more than one profiling device, so that question is only ever going to get the answer "I've got this one, so I think it's the best".
thats true... but i done my home work before i bought it and i can compare it to higher end devices as well...
I think munki will give you perfect time playing with colors :)
WorthDoingRight
Well I am waiting for a Colorvision Spyder 3 print to arrive. I bought it new boxed off eBay for what I consider not a lot. Once I have tried it out I will let you know. I can almost see us having to have a 3 way test soon lol.
Andrew
Post by Andrew »
I will have to do a bit more research then but good to get direct opinions on here. Just had a swine of a print job and struggled on a gradient. Got about 20 mugs waste and still not happy with the result.
Andrew;55042 wrote:I will have to do a bit more research then but good to get direct opinions on here. Just had a swine of a print job and struggled on a gradient. Got about 20 mugs waste and still not happy with the result.
you can not print gradient with my profile?? :eek:
I've got a Spyder system, which has two devices, one for printer profiling, and one for monitor profiling. From what I remember it does more colour swatches for printer profiling than the Munki, but not quite as many as Paul's system, but not far off.
Andrew
Post by Andrew »
Paul;55043 wrote:you can not print gradient with my profile?? :eek:
Struggling with a yellow into greenish colour. Not sure why but there is a big step in it. I would have hot a profile for this design as it was important but also urgent.
hmmm... i never seen uneven gradient with my profile yet...
