D120 ink levels
Re: D120 ink levels
Hi Everyone,
I have a D120 with ciss, with the reset button on top for the chips.
Does anyone know how or if all the ink levels can be set to full together, as it only seems to do one at a time and i'm fed up with it stopping during printing for each colour.
Thanks in advance.
Thanks in advance.
Re: D120 ink levels
Is this an easyflow CIS do you know? Does the CIS auto reset when the ink runs out or do you have to press the reset button each time?
Re: D120 ink levels
I don't believe it's possible to get them to "factory reset" so they all read full like they would have done when first installed. The chips should reset back to full when they get very low and the printer/ computer is restarted. If the chip goes "empty" during the actual printing process then it will need a manual reset or the printer to be switched off/on which should do the reset for you.
Re: D120 ink levels
Justin, its the one you have to press the reset button each time.
Martin, the R1400 we had used to reset itself when switched off, but the D120 we have doesn't.
Re: D120 ink levels
Never seen one with the reset button until I bought this one for my 1400 so I guess they're the same. My inks are showing very low and havn't automatically reset...and the button doesn't seem to work either
Sounds like I have the same problem as you.
Re: D120 ink levels
We've tried to reset it when the inks show low before printing but it doesn't work, it'll only reset when it's actually stopped printing half way through a print, which is really annoying!
Re: D120 ink levels
Ours does, not sure if its supposed too!
When we press the orange button on the printer to get the cartridge in position to press the reset button, it throws the paper out, then it allows you to reset the colour thats low (not all).
At the moment ours is showing nearly all colours are low (except yellow which was done today) I'm scared to do a print because we know it'll stop, just not sure if it'll be 1 or 4 times
Do you know if the one with the reset button is the newer system?
Re: D120 ink levels
I assume it must be as I only just bought mine, previous CIS I had didn't have the button, not sure why it's needed when before they just auto reset no problem.
Re: D120 ink levels
Patience my friendNever seen one with the reset button until I bought this one for my 1400 so I guess they're the same. My inks are showing very low and havn't automatically reset...and the button doesn't seem to work either Sounds like I have the same problem as you.
The reset button is an over-ride so can only be used once the chip hasn't reset itself, not before.So the reset only kicks in when the cart is showing as totally empty then?
I believe any printer will stop printing if the cart goes "empty" (according to the chip) during a printing process. My understanding is the printer reads the chip before starting the print job and then prints, stopping when the chip reports the cart is empty. So if you had any printer and set your printer to print overnight then it would stop at somepoint when one of the chips showed empty. The reseting occurs during a restart or reboot (in theory).
