Help Please with printing dilemma
Adrian
Re: Help Please with printing dilemma
Post by Adrian »
Hello,
I posted an earlier thread about printing onto ceramic plates. I would like to buy a good printer (probably a Ricoh) so that I can print my art work ready for pressing. My problem is I'm unsure about how successful the ceramic process might be and I am hesitating on spending £ 300.00 + on printer and inks.
Is there anyone willing to print a bit of my artwork onto sublimation paper and return so that I can have a go first? I can email a file no problem - I already have Photoshop.
Alternatively are there web sites who will print art work for you onto sublimation paper.
I am able to return the press if I am not happy with it (14 days) I think so any help would be appreciated.
Thnx.
Adrian
Adrian;59374 wrote:Hello,
Thnx.
Adrian
I think this could be problematic for you for a number of reasons... (1) plates are notoriously prone to cracking when 190 degrees of heat is thrust into the centre of a plate with pressure of the press coming down on it (2) for sublimation to work the area has to be flat and smooth and plates centres often are not flat. Try putting a straight edge over the centre of the plate middle and you'll find they are not flat so there isn't a perfect surface for the inks to bond with resulting in a fade out of the image. (3) Your own plates won't be sublimation ready so you'll have to apply a spray to the surface and these sprays/ polymer liquids need several layers to get a decent surface coating.
Check the terms of sale of the plate press as there are few companies that offer them on a sale, try and return basis.
Adrian
Post by Adrian »
Thanks very much Martin...do you have any further advice on polymer sprays? I had a quick look on your site but was unable to see any.
Kind regards
Adrian
Adrian;59382 wrote:Thanks very much Martin...do you have any further advice on polymer sprays? I had a quick look on your site but was unable to see any.
Kind regards
Adrian
Sorry can't help with polymer sprays as we don't supply this type of product. I think you'll need to search for Digicoat or something like that.
RogerC
Post by RogerC »
Adrian if you get the plates sorted and still need someone to print for you drop me a message on here and we can sort something out.
Adrian
Post by Adrian »
Hi Roger...many thanks for the offer...I'll be in touch.
Kind regards
Adrian
Ian M
Post by Ian M »
Adrian, Subli Metals do the coatings & they can be found at this link http://www.sublimetal.co.uk/?wpsc_produ ... ther-items
There are a couple of videos you might like to watch first showing how to use the coatings at these links http://www.youtube.com/watch?v=F1Y9cZxTgLw http://www.youtube.com/watch?v=RWxXgF88GJY
