Ricoh 3300 cleaning
ljmatth
Re: Ricoh 3300 cleaning
Post by ljmatth »
Hello,
Having trouble with print quality. I'm printing black on to white and after it's printed I'm left with 2 feint (but still visible) lines running vertically through the design. I'm sure it's from residual ink left on the rollers, but not sure how I clean them. I've cleaned and flushed the heads/nozzles but that hasn't solved the problem. Any suggestions?
lisa
WorthDoingRight
Post by WorthDoingRight »
Well if it is on the rollers or path then you could try my method which is to just send an A4 document to the printer with just a single full stop on (so pretty much a blank sheet) using cheap white paper and repeat until it clears (if it is going to then you should see a difference after 10 sheets)
Ian M
Post by Ian M »
Lisa, you might find this video useful.
carter2
Post by carter2 »
This problem is found in many Ricoh pirnters..:frown:You can just simply open the print tray and clean it with the spray or cleansing kit given to you and if it persist just simply re-install the software again..:smile:
carter2
Post by carter2 »
This problem is found in many Ricoh printers..:frown:You can just simply open the print tray and clean it with the spray or cleansing kit given to you and if it persist just simply re-install the software again..:smile:
