Ricoh e3300n won't switch on
marshallsmugs
Re: Ricoh e3300n won't switch on
Post by marshallsmugs »
I hope somebody can help, I went to turn our 3300 on but the lights flash for about a second and then it goes dead. Any ideas or should we get a new printer?
Peter
looks like common fault with this printer. it was widely discussed on forums.
if this is same fault then printer is dead. :(
marshallsmugs;60046 wrote:I hope somebody can help, I went to turn our 3300 on but the lights flash for about a second and then it goes dead. Any ideas or should we get a new printer?
Peter
I'd advise to get in contact with your supplier. They will need details of when you bought the printer, serial number of printer, batch numbers of cartridges and some extra info, but they should be able to provide warranty or incentive upgrade options for you.
marshallsmugs
Thanks for your prompt replies, I suspect it's out of warranty but I will give mega a call as it hasn't been used very much.
carter2
Post by carter2 »
Unpack and setup the printer as described in the printer setup instructions. Have the printer plugged into a power outlet but not turned on. IMPORTANT: DO NOT ...INSTALLING SUBLIMATION INK. Do not power ON the printer before installing the cartridges. Remove the Sublimation ...cover. Note: DO NOT TURN ON THE POWER FOR THE PRINTER UNTIL THE DRIVER INSTALLATION REQUIRES YOU TO DO SO...
Craig
Post by Craig »
carter2;60063 wrote:Unpack and setup the printer as described in the printer setup instructions. Have the printer plugged into a power outlet but not turned on. IMPORTANT: DO NOT ...INSTALLING SUBLIMATION INK. Do not power ON the printer before installing the cartridges. Remove the Sublimation ...cover. Note: DO NOT TURN ON THE POWER FOR THE PRINTER UNTIL THE DRIVER INSTALLATION REQUIRES YOU TO DO SO...
Im not to sure what this has to do with the printer not switching on?:confused:
I'm not sure about Carter2
Iam not sure about him too...
All random msgs he post...
mrs maggot
Post by mrs maggot »
i am convinced carter is an it rather than a person
marshallsmugs;60050 wrote:Thanks for your prompt replies, I suspect it's out of warranty but I will give mega a call as it hasn't been used very much.
If its within 2 years of purchase you should get a deal.
