help
guarddog14
Re: help
there is a epson 1100 at a3 size that i have been offered at 125 with sub ink in around a quarter full , seems ok to me what is your guys thought os it , would i have issues sorting the colour profiles out etc? also selling a mug press below 50 and a heat press at 170 , trying to get a everything in the pack deal?
Re: help
Hi Guarddog14
If it seems to good to be true it probably is. £345 for printer, mug press and heat press is very cheap and I personally would question the quality of the items. I understand that as you are starting out the items do not need to be industrial strength but the heat press element and accuracy of the temperature are fundamental to your ability to create printed items.
Personally, I would save more and purchase a Ricoh from a reputable sublimation supplier. Pisquee has pointed out that there have been problems with Ricohs, but firstly they are in America so it could well be a power source problem, secondly, the link he put was from a thread back in January 2012. If this was a major problem it would have been sorted by now. If you need more assurance then ask the expert sublimation suppliers how many problems they have had with a) Ricoh's and b) Epsons (especially unsupported models) there will be a significant difference.
Likewise with the presses. A decent mug press will cost you £150 new. Yes, three times the cost of the one advertised, but if the mug press is no good you will spend £100.00 on mugs very quickly trying to get it to print a decent image.
In short there are two sets of "newbies" on here.
Ones who buy cheap and then post constant questions about how to solve a problem
Others who buy recommended kit from a reputable supplier who post constant questions about where to source new and exiting products. Its up to you which camp you want to be in.
guarddog14
Re: help
ta mate i shall bear this in mind, its all 2nd hand so would make sense as to being a bit cheaper, however some really intresting developments today , and basically i might be getting a wide format printer a mimaki cvj30-100 but still negotiating wish me look and hopefully i will soon have a very decent bit of kit that i alreay know how to use
- harlequeen
Re: help
I agree with what you are saying Socialgiraffe. I almost bought an 'everything you need to print mugs' package from a supplier, and on a hunch I rang to check if ink was included and they were very evasive. I ended up buying a package from BMS and have never regretted it. I am now branching out this Christmas with new, exciting products. LOL
Re: help
If you can go wide format, can see benefits for your business in being able to sublimate that big, have the space for it etc, then you will end up with a much better quality machine that is built for commercial/industrial use, rather than a cheap/domestic/home printer. You can then also buy sublimation inks which are much better quality than those available to users with small printers, and the cost/ml is about 1/10th of the price!
(This is what we did, and have no regrets!)
Re: help
"i might be getting a wide format printer a mimaki cvj30-100"
oohh wide format print and cut, have a Roland myself with white and pearlescent colour option, best piece of kit I purchased, simply fantastic.
guarddog14
Re: help
its not a sub one its a solvent ink one , but banners and poster / popups can be made on it ,
