GX7000 intermitent printing
steve121
Re: GX7000 intermitent printing
Post by steve121 »
Hi guys. I'm having problems with my Richo GX7000 only printing when it wants to. Basically, sometimes it prints fine then other times I just get a printed band around 10mm then nothing, not even any streaking across the page. I get the band and nothing more often than a good print. I've just installed Power Driver and the problem is still there, I even installed a fresh set of inks in case it was a cart chip problem and still the problem exists. I've tried the head cleaning etc to no avail. This is driving me mad.
Can anybody advise me what else I can check please?
Steve
RogerC
Post by RogerC »
Give BMS a call....they are a mine of information and might be able to help. Good luck.
John G
Post by John G »
Your first port of call is where you bought it from - they be able to put you on the right track, sounds like set up to me.
Also, have a read through on T-Shirt Forums - lots of discussions on similar problems on this model over there.
steve121
Post by steve121 »
Thanks for the advice people, much appreciated. The same computer is also the one I use for vinyl cutting. I did a cut vinyl job today and had a similar problem arise when cutting. The machine seemed to hesitate while cutting as if the data was flowing very slowly, so it could be a spooling problem. I have a spare day tomorrow, so I'm going to give the the machine a damn good clean out and service plus check all cable connections and leads. If push comes to shove I may even reinstall the operating system (after a full backup) as I recently removed a few old unused graphic programs that I didn't use to free up space, maybe this removed a few things that shouldn't have been removed. I'll try upgrading and reinstalling all drivers first and see what happens.
Steve
steve121
Post by steve121 »
Quick update. After much hairpulling I resorted to a full reinstall of windows and all associated bits inc up to date drivers for everything. All seemed fine till I went to do a print ...... Nothing! I went through the set up again 'word by word' along with a double check of every click and setting - still nothing. I finally resorted to a phone call to Xpres and spent an hour or so on the phone to a very helpful person on their tech support. He was nearly as baffled as I was and finally suggested a 'Firmware' upgrade may be in order. This I did while he waited and all is now good on the print front at long last.
I am now a Happy Bunny and can get on with some work at last.
Thanks again for advice.
Steve
RogerC
Post by RogerC »
steve121;63673 wrote:Quick update. After much hairpulling I resorted to a full reinstall of windows and all associated bits inc up to date drivers for everything. All seemed fine till I went to do a print ...... Nothing! I went through the set up again 'word by word' along with a double check of every click and setting - still nothing. I finally resorted to a phone call to Xpres and spent an hour or so on the phone to a very helpful person on their tech support. He was nearly as baffled as I was and finally suggested a 'Firmware' upgrade may be in order. This I did while he waited and all is now good on the print front at long last.
Steve
Don't you just love it when problems like this are resolved........it restores your faith.
