Printing on bottom of mugs
Re: Printing on bottom of mugs
I have seen those as well,
i did wonder if they were vinyl (seen glasses with vinyl on) but it does say they are printed.
There may be over spray but they aren't specifically coated. There were a couple of members here that did the solvent stickers from memory, but this may help:John G;64131 wrote:Just tried on a swing away flat bed heat press - there doesn't seem to be any sublimation coating whatsoever on the bottom of BMS mugs as there wasn't even a faint print left after 190/190 with 2 sheets of silicon. Maybe Martin can confirm whether there is a coating on the bottom of the mugs or not.
Cheers John
http://www.dyesubforum.co.uk/vbforum/sh ... -mug-bases
I can offer eco solvent ink printed decals/stickers (call them what you will) on clear or white vinyl to forum members if it helps. Full colour printed on a Versacamm.bms;64156 wrote:There may be over spray but they aren't specifically coated. There were a couple of members here that did the solvent stickers from memory,
Yep, these (http://www.ebay.co.uk/itm/Surprise-I...item3a7de39e1e) are the ones, so how are they doing it then?
- mrs maggot
As Gorgall says probably with a pad printer
Sorry for my ignorance, but what is a pad printer, please? Where does one get one from, and how much are they?
- mrs maggot
James, just google pad printing, and you will find thousands of entries, close to the top will be you tube videos explaining the process, and further down equipment sellers, but its not something cheap as such - but google and you will find
