Best/Most appropriate software for designing my mugs!
Any OS, software in here.
ck1
Re: Best/Most appropriate software for designing my mugs!
Post by ck1 »
Hi Everybody,
As I get ever closer to buying my mug pres kit I was wondering which grafix package people generally use?
At the minute I am looking at the latest offerings from Corel and photoshop (elements)
Is their anything that one package does better than the other?
I will be primarily making mug templates with 'fancy' fonts/lettering and including pictures(graphic and photo)
As clients will be sending pictures in I will need to be able to 'enhance' these as required
Chris
for enhancing i recommend adobe. Both packages would do the job but the are different.
Can you tell what printer you going to use?
ck1
Post by ck1 »
Hello - I'm intending to by the starter kit from BMS with the a4 Ricoh printer, and I'll be using the power driver software
If you going to use ricoh and its powerdriver then your choice is much, much wider! Powerdriver can print out of anything! so whatever is comfortable for you to use can be used :)
ck1
Post by ck1 »
Super - used photoshop recently, but have used Corel in the dim past - are the features comparable, or is it horse for courses?
corel is vector graphic software and photoshop is raster graphic software. so is like comparing apples to pears :)
both are good but photoshop better for the job in my opinion.
if you planing to do some cutting in future then corel is your mate. as it can do both :)
Do you mean CorelDraw or CoralPhoto though?
corelDraw. sorry. :)
ck1
Post by ck1 »
Right then, photoshop it is ( for now, anyway!)
Renniwano
Post by Renniwano »
I use both.. Corel X3 and Photoshop CS5
I do a lot of my clean up work etc in Photoshop.. but my template is in Corel.. lol
Users browsing this forum: Amazon [Bot] and 5 guests
