Waned supplier of oval blanks
johnfrancis
johnfrancis
Re: Waned supplier of oval blanks
Thank You for your quick replay. Blanks Sizes these are all cm 8x10 9x12 10x13 11x15 and 13x18 Sizes other than these would be fine. BMS would import Min order 500 of each plus £55 for pallet if I was to order over £1500 in goods I would expect no delivery charge.
whats the oval blanks?? ceramics? pastic? plaques?? or anything that is oval?
johnfrancis
That's a good pallet rate. Why should you expect anything? It is easier for BMS to quote plus the delivery, otherwise, if it would make you happier, I am sure they could raise the unit cost by 2.2p and say that the delivery is included.johnfrancis;66266 wrote:BMS would import Min order 500 of each plus £55 for pallet if I was to order over £1500 in goods I would expect no delivery charge.
I too am at a loss as to why £1500 should mean free delivery.
And I agree £55.00 is a pretty good pallet rate.
Free delivery is not usualy free, its inclusive, either way the buyer pays one way or another.
johnfrancis
Ive taken it on the chin with the gaff I made about delivery charge. You have made your point and your right. What I had in mind was to print photographs onto there ovals but it is very difficult to sauce these items.I could do with a little help..........and any help will be most great full.
Hi Johnfrancis
Not sure on sublimatable ones but I do know that some members on here purchase standard white tiles from the local tile centre and coat their own using digicoat. It might be worth looking to see if there are any shops around your way that sell standard ovals which you can then coat yourself.
