desperate sheild
Re: desperate sheild
http://www.unisub.com/templates/templates_main.html
http://www.rowmark.com/sublimation/Sublimationsamplestemplates.asp
Couple of quick site ideas....keep us posted, I'm sure I could knock something up if it's not there.
Justin :-)
jennywren
Post by jennywren »
Could you knock up a template for me , I running out of time I'm suppose to take it to work for them tomorrow, The pubs opening on Wednesday Image
I'll see what I can do
I've just uploaded an outline into your gallery, take a quick look. This is based upon a standard shield template but done to your measurements. Looking at yours in appears slightly different shape but I've found one that may be closer.
Justin :-)
jennywren
Post by jennywren »
What a nightmare but in the end I did a rectacle and put the image in it, and it worked, never again I hate rush jobs its for a pub thats opening Wednesday but wanted it monday morning and the art work was a fiddle, hours of work but at least if anyone asked again it should prove straight forwared, many thanks for the time all of you have put in to help me.
Were the frame outlines no good?
jennywren
Post by jennywren »
the frame was slight smaller than I needed I made it bigger but when I went to layer it it was two and half of inches smaller. but unlayered it was the right size and having a long day I did the best I could. Any ideas how I made it smaller by flatten it.
It prob had an invisible layer around it, I just posted them ther quickly to get an idea what you wanted.
Let me know if you need something better and I will sort it.
Cheers,
Justin :-)
jennywren
Post by jennywren »
Et was invisible, I did'nt see it :D I you have with out the extra layer
I can send the outline in whatever format you need, just let me know and I'll post it up.
