Coral 4 mug press?
Re: Coral 4 mug press?
Does anyone know if the coral 4 mug press is 10oz or 11oz and do you have to buy a new sleeve to do the other? many thanks.
I would expect it to be 11oz but check with supplier. I use 3mm silicone inserts to press smaller mugs/bottles etc, works a treat
Is that both with the standard mug blanket or would you need to buy a second one. Ie can one blanket do both?viccar;75459 wrote:coral 4 does both
thats with the same blanket mine does both with no problems.
I have used
coralgraph 10 and 11 oz
BMS 10 and 11 oz
Longforte 10 and 11oz
all no probs.
I have used
BMS 10 and 11 oz
all no probs.
Specification: Pressing Size: Diameter 7.5~8.5cm Temperature Range:0-220 Timing Range: 0-999 Sec. Voltage: 220V-250V,50HZ Power: 450W Fitted with 13 Amp Fuse Size (L W H): 27X29X25.5cm Packing size: 38X35X28Cm Net Weight: 9Kg Gross Weight: 10Kg Product color yellow or black
I take it your using one of these....how do you find it?viccar;75467 wrote:Specification: Pressing Size: Diameter 7.5~8.5cm Temperature Range:0-220 Timing Range: 0-999 Sec. Voltage: 220V-250V,50HZ Power: 450W Fitted with 13 Amp Fuse Size (L W H): 27X29X25.5cm Packing size: 38X35X28Cm Net Weight: 9Kg Gross Weight: 10Kg Product color yellow or black
I find it fine and easy to use, although i dont print that many mugs, ive printed a few hundred on it and all have been good.
Only problem i ever had was my fault, purchasing cheap ebay mugs, lesson soon learned there.!
I bought the coral 4 starter pack.
I got that as well what settings do you use...? I have been getting sort of dark stripes and faded colours. Had a great Mug but on the advice of an expert....lol I did warn him, it cracked after going into cold water. Fun and games and 36 mugs down the river lol
