Metal plaques
Discuss other print methods.
Re: Metal plaques
do you know anyone simon that has a oki white
Funny you should say that.... yes I do... Me!
Also Jason and Logobear for sure have them. There are probably others that I may have forgotten.
OKI White is the OKI711WT pinter. It prints using CMY and WHITE toner.
A11kns
Re: Metal plaques
Post by A11kns »
Just seen a video on this... Very good, but sadly way out of my price range just for me to buy for my club.
Re: Metal plaques
I would suggest you contact TMT, they will be able to put you in contact with someone who has a white printer in your area. I am sure they would be happy to run a few sheets for you at a decent price.
I know that me, logobear and Jason would do the same but you would have to pay postage
Re: Metal plaques
The Magic Touch
Ask_Alan
Re: Metal plaques
Post by Ask_Alan »
hi
That original looks engraved and filled with paint - Local trophy shop can do that. the C711WT transfer will be on the metal and need a clearcoat for outdoor toughness
Alan
A11kns
Re: Metal plaques
Post by A11kns »
Yes you are right Alan.. but to produce the amount I need to will be expensive. I'm happy with my result so far, but will look better with a little tweak and Simon and his white printer ;)
A11kns
Re: Metal plaques
Post by A11kns »
Well got paper from Simon (thanks Simon) I've pressed some plaques but not getting results I'd expect.
The first two are either 80% or 100% white and the last is the first I printed without white... I thought the others would if looked brighter and better... What am I doing wrong? I'm pressing at 170deg for 2min
Ask_Alan
Re: Metal plaques
Post by Ask_Alan »
Just how are you pressing the CPM paper?
Toner on to metal needs a slow bake. You need an A-Pad (5mm thick silicone rubber pad) then place metal on the press, CPM facing it and the pad over the top. press 160/165 for 2 minuites at a medium to high pressure.
Remove from press, allow to cool and then peel the CPM off. Video here http://www.themagictouch.tv/cpmtrophy.html
To gloss and harden the result place the peeled metal toner side up under the press and "grill" the finished plate for 3-4 minuites, this will melt the surface giving a bit of a gloss and harden it.
For the brave a blowtorch can be waved over the result to do the same but care is needed to prevent burning!
The images look like the toner boiled :(
Clean toner off with acetone, you may get slight shadow left but usually overprintable
alan
