Newbe - Help
wilky007
Re: Newbe - Help
Post by wilky007 »
Advice needed
Thinking of starting up vinyl cutting as a hobby and been looking at cutting machines, What should I be looking for when reviewing the machines? Ie - what software, machine spec ect ect?
Any advice would be appreciated.
Thank You
Dave271069
Re: Newbe - Help
Post by Dave271069 »
What type of vinyl cutting, eg t-shirts etc?
if your new to it the silhouette cameo is a excellent cutter with very easy to use software. If your looking at something bigger than 12" then it all goes on how much money you want to spend?
wilky007
Re: Newbe - Help
Post by wilky007 »
It will be mainly for signs about a3 size as for budget looking about £200
RogerC
Re: Newbe - Help
Post by RogerC »
Wilky,
In all honesty your budget will not cover what you would like to do. Apart from a cutter (plotter) you'll need software, a cutting mat and a selection of tools. A 'cheap' plotter will, as some have discovered be more trouble than it is worth..............buy cheap buy twice is the adage here.
