FlexiSign 10 Black Lines over everything.
Re: FlexiSign 10 Black Lines over everything.
NikGrey;77795 wrote:Paul - Didn't you make a video using your 'Sample' from Yolo ?
only this one i think
http://www.youtube.com/watch?v=LnlN9r5XqU4
NikGrey
Post by NikGrey »
I have been watching sooo many video's it becomes a blur.. I was thinking of a video which was making a Banana shirt for the persons daughter - I thought it was you !
I do think your video's are very clear, and you explain things very well.
NikGrey
Post by NikGrey »
That's the One - and I fully share your thoughts toward the 'Optical Eye' (Waste of time).
I am almost there with my T-Shirt printing, I had the 'Masking Tape' come today from Yolo but there is a problem with it so I am awaiting a response from them.
Anyway, can you help with this.
I am creating my design in Photoshop, saving it with the background layer deleted - opening it Flexi and getting it ready for Contour cut.. saing the Flexi file AND a .jpg (With Reg Marks) so I can print in Photoshop BUT, for some reason Flexi is saving my file at 72dpi and I want what I designed it in, 300dpi.
Is there a way to make it save things in a custom resolution? as at the moment all my hard work is being degraded !
GoldRapt
Has thanked: 6 times
Been thanked: 7 times
Post by GoldRapt »
Nik, why cant you print in Flexi?
regards
Tony
-launching july/august 2026
NikGrey
Post by NikGrey »
I can but I haven't found a way to use my ICC profile in Flexi, I should get better prints from Photoshop so am trying to get that to work as I want - I wont compromise though, 72dpi is just not good enough.
I have a lot riding on this so need to get it right, I will get a lot of work if I can pull this off.
i dont think flexiStarter has a option of using icc.
flexi sign has...
windyash
Post by windyash »
A bit off topic but what is the main differences between Flexi starter and Flexisign ?
Mimaki CG60-st cutter , Ricoh 3110 sub printer , OKi laser , Epson inkjet , 2x heat press , mug press , cap press, Flexisign pro and coreldraw X6..............and learning ...........
and now a Roland SP-300v Versacamm !!!!!!
GoldRapt
Post by GoldRapt »
A couple of grand for starters.
If you have flexi starter, download a copy of the full flexi and check it out.
The real difference I suppose is if you have print and cut machines.
regards
Tony
windyash
Post by windyash »
I got flexi pro with my secondhand cutter and my computer has gone up the creak so will need to get a new copy , and flexistarter is a lot cheaper!!!!!
