i am having a little trouble with my heat press the fuse has blown and i have looked everywhere to get the right fuses
all the fuses i get seem to be too big to fit into the fuse holder or not enough amps to power my heat press
my flat tshirt heat press is newish and i have not had a problem with it before.
i purchased it from coralgraph and there "tech team" require an email before they even help you and do not have a phone number for them.
all i need to know is, if any one can help, is where to find the right fuse for my heat press
will i try a botch diy job and get some fuse wire and go from there?
details for press- standard 8in1 heat press from coralgraph,1200 watts model-hp8in1
Thanks in Advance
Carl
Designandgift
