help please
Re: help please
Information on Sublimation Printing needed
Tried to sublimation print on a t-shirt for the first time this evening using sublimation ink and paper, printed onto the t-shirt, printed at 190 for 90 seconds after a few attempts at advised settings, it has printed on the t-shirt but very light print.
Any Ideas??????????
Any Ideas??????????
Re: help please
is the t-shirt cotton or polyester
are you sure that the inks are sublimation?
Is your press set for C of F temperatures?
Re: help please
the t shirt is cotton yes it's the same I use for my mugs as for temp I think it is on c as I don't have a manual for it I got it free with a job I did for some one it is cheap onepisquee;81830 wrote:is the t-shirt cotton or polyester
Re: help please
you can NOT sublimate on pure cotton. you need polyester t-shirt or high polyester content in your cotton
Re: help please
would that be the same problem with my mouse mats?Paul;81836 wrote:you can NOT sublimate on pure cotton. you need polyester t-shirt or high polyester content in your cotton
Re: help please
if you have a blank mouse mats from sublimation blanks supplier then no. they are toped with polyester fabric on top and should print with no problem. Why? you have this same problem?
Re: help please
yes I am having the same problem with them and I have the same press as you have paulPaul;81839 wrote:if you have a blank mouse mats from sublimation blanks supplier then no. they are toped with polyester fabric on top and should print with no problem. Why? you have this same problem?
Re: help please
are you sure you have sublimation inks then?
Re: help please
i am not 100% but my mugs are greatPaul;81845 wrote:are you sure you have sublimation inks then?
Re: help please
so if ink transfer to the mugs then it is sublimation ink. maybe something wrong with your press? how high the temperature clock go???
