Printing Required
johnfrancis
Re: Printing Required
Post by johnfrancis »
Hi Guys. I need a little I am a photographer and would like some advice, I need some one to print Decals on a regular basis, which is best ceramic toners or sub ink. I will then heat press on ceramic ovals. Thanks.J.Rutherord
For you to be able to use sublimation transfers the ceramic ovals would need to be coated for sublimation use. Sublimation would get you best results, if you can find the ceramics available then I would go this way.
We can do the tranfers for sublimation if you want, along with many others on here I'm sure.
johnfrancis
pisquee;83022 wrote:For you to be able to use sublimation transfers the ceramic ovals would need to be coated for sublimation use. Sublimation would get you best results, if you can find the ceramics available then I would go this way.
Many thanks for reply. I do have a supplier in mind. I would need prints to be oval shaped, have you a sample printed on any shape as long as it a ceramic. Please let me no cost of sample and postage. I Live in Lincoln LN2 . How would you work your costing please the size will be 6inch x 4 inch. This will be on a regular basis. I look forward to your reply.
J.Rutherford
How many transfers would you require printing per batch - we print on wide format printers, so for us to do the job, it would best for you to fill up an A2 sheet or larger with as many images that would fit.
We would charge a flat rate depending on the size of page needed, plus delivery.
If you're only needing one or two at a time, then there may be other members better suited to serve you, maybe even more local.
johnfrancis
Hi. What would be your min order. Do you have a sample i can purchase on some type of base material so I can view finish. Thanks J.Rutherford
Users browsing this forum: No registered users and 14 guests
