Spray Glue
Re: Spray Glue
What glue are you guys using? I'm going to make some lanyards and the only stuff I have seen is £16 a can!
Re: Spray Glue
We use 3M 75 Scotch-Weld spray
http://www.vikingtapes.co.uk/p-747-3m-s ... znlLPnkoS4
available from loads of other suppliers
You only need a very light spray/mist of it, so each can does last, especially if you're doing lanyards - we're using it on metres of fabric at a time.
Re: Spray Glue
Thank you. Lazy me really.. I went on a google search and found it being spoken about on here.
Is there any place I buy it over the counter?
Re: Spray Glue
No idea about over the counter, you'd likely pay more for it from a B&M store though.
We've also used this supplier for it:
http://www.transair.co.uk/sp+3M-NO75-Sp ... P208061116
Re: Spray Glue
I got some re positional adhesive from hobby craft today. Its ok, but like you said you don't need much at all!!
I have been using a method I saw in this video.
I am using grease proof paper to protect the lanyard but sometimes it sticks to my glue and I have to bin it.. is there a better option or am I having this trouble because of my glue?
Re: Spray Glue
If using on a t shirt for example does the tshirt need washing after pressing? Is it still sticky? Do you spray it on the fabric or the print?
Janners
Janners
Re: Spray Glue
We spray it on either the fabric or paper - whichever is easier for the job we're doing. The spray leaves a residue if used on hard substrates unfortunately, but is not noticeable on fabric so doesn't need washing out.
I expect that you're having problems with the stuff from Hobby Craft, as you're not just needing re-positionable adhesive spray - it needs to be OK with the heat in the heat press, which is one of the properties of the 3M spray we use.
There is spray sold specifically for sublimation work, but this appears to be quite generic cans that have been rebranded, so I would rather just buy the original product, without paying a surcharge for it saying "sublimation" on the can.
Re: Spray Glue
Cheers Tim,
I rarely do soft stuff, but occasionally
get asked for promo t shirts.
Janners
Janners
OurSchoolBadge
Re: Spray Glue
Have a look at 505 Adhesive. It's designed for temporary gluing of paper and fabric. No residue.
Re: Spray Glue
It's not just repositionable spray adhesive that's needed, it need to be OK with the heat from a heat press - does the 505 do this? - the 3M 75 is designed for high temp work. The 505 seems about the same price per ml as the 75, so why not get the 75?
Users browsing this forum: No registered users and 13 guests
