Mug Press for Sparta Mugs
Jason
Re: Mug Press for Sparta Mugs
Post by Jason »
Can anybody recommend a good well priced mug press for Sparta Mugs, looking at getting a couple to complete an order I have for these.
Reg
Post by Reg »
Just use a silicon rap in your normal press.
You might need something a bit thicker than a silicon wrap, possibly cut up a soft pad.
If that fails, would it not be cheaper to purchase the correct blankets for your current mug press?
If not then I can recommend the Listawood Genie. Normally I would offer to send it over for you to use and then send back, but am currently using it for a shag load of water bottles.
purpledragon
Post by purpledragon »
socialgiraffe;87987 wrote: but am currently using it for a shag load of water bottles.
what interesting termanolagy lol
Jason
Post by Jason »
Cheers Chaps, No problem purchasing the correct blanket but I'm not sure what the correct blanket is for these.
Listawood
Post by Listawood »
It may be worth trying a sparta in your standard press before purchasing a new blanket, you may find that if you leave the lip of the mug out of the press you can get it to press in the standard Durham attachment. Give me a shout if you want me to send you a sample sparta mug to try on 01485 529715 or email becki.white@listawood.com.
Cheers,
Becki
purpledragon
can you send me 36 samples Becki ?
I'll take 108 (sorry I have got too many customers) :wink:
purpledragon
If it helps ive printed sparta mugs in a standard press using a thin silacone wrap and theyve come out fine just up your times a bit and do as Becki suggested but if doing a lot of these its worth buying a thicker blanket
Listawood
Post by Listawood »
purpledragon;88006 wrote:can you send me 36 samples Becki ?
Good try :-)
