Any issues w/ iPhone 4/4S 3D case sizing?
3D Sublimation
gnarkip
Re: Any issues w/ iPhone 4/4S 3D case sizing?
Post by gnarkip »
Hey all!
I'm over in the US, and I've been doing 3D dye-sublimation for a few months now. I have both a mini 3D machine and a larger briefcase machine, but I mostly do cell phone cases at the moment. I feel like you guys here are the only ones with any real info on the 3D processes at the moment! I've just been getting into playing with some films, but that's for another time..
Just a quick question this evening, though -- do you have any issues with the iPhone 4/4S cases, or have a good source for ones that absolutely fit? I have gotten two different case types, from two different vendors, and neither of them fit. :( The first is too big width and height-wise by more than a couple millimeters, and the second is snug in the width but still at least 2mm too tall, and the phones just slip around like crazy inside. Any help/good sources possibly? Thanks a ton!!
Are they are to big after pressing? As i found cases bit larger but only before i put them in to the heatpress
ArtyGamer
Post by ArtyGamer »
I use the Bestsub iPhone cases as I've found that they're the most sturdy and take the dye better than cheaper cases. Best suggestion would be to check the Bestsub site for your local area: http://www.bestsub.com/contact-us/distributors
