Problem with image not transferring onto mug
Simong12
Re: Problem with image not transferring onto mug
Post by Simong12 »
is there any way i can test the ink, as i need to prove its wrong. as i brought machine last april?
you just did that :) no image transferred to the mug :)
Simong12
Post by Simong12 »
i suppose your right, but would i have contamination if i had sublimation ink in pipes, just grasping at straws, cant afford to buy new printer at momment.
Scotty@BMS
Post by Scotty@BMS »
If all the inks you're using are the same as the cartridge pictured, what I say is not conjecture but certainty. You have Ricoh ink.
Users browsing this forum: Amazon [Bot], Google [Bot] and 1 guest
