Redesigned website
Area to discuss all forms of website,design, commerce etc.
Mattie
Re: Redesigned website
Post by Mattie »
Yeah we you on that page click "edit elements" and remove the template so you end up with just the customers design then save that ready for printing
Matthew
Vynmarius
Post by Vynmarius »
so when you do that you get a clipped image sized ready to print ?
Mattie
Post by Mattie »
Unfortunately not you would get the full image uploaded by the customer but you could then crop it in photoshop
You could also download the image with the template and use that as a guide where to place the original image
Or make your template slightly bigger on the designer so when you download it you can crop it so that you get rid of the template and just have the cropped image ready for printing
It just finding a way that your comfortable doing
Matthew
Vynmarius
Post by Vynmarius »
yeah the larger designer seems best, but I can imagine its annoying having to go through these steps when dealing with many orders! i wish it was print ready straight from the designer, do you use a theme with your site as I read that the designer comes with its own?
Mattie
Post by Mattie »
I find it quite easy as all my templates have bleed area so I Dow load the full image open it in coreldraw and crop the template away and print it
The designer has a theme as such just in the way that you can change the colour of the bar in the settings and control where the elements box appears e.g left, top etc but it wouldn't alter open cart your best off buying a good theme or create your own
Matthew
Vynmarius
Post by Vynmarius »
Found my way to do this, I will have a blank (phone mug etc)template in png form set as the top layer, customer uploads their pic underneath then all they can see is their clipped image on screen. customer approves product design and pays!
in the back end i look at their order, remove my template and leave their edited parts (photo, text etc) then export this to a pdf in jpeg form ( as png seems to be broken once template is removed)
This leave me with a pdf of their design minus my blank template ready for printing, to make sure the size is correct i will not choose fit to page.
once printed i will just match up the image "by eye" to the substrate and tape and transfer!
It would be better if i had a system setup to make the "by eye" redundant as I feel this will be hard in future, Is that where Corel come into play ?
Does this method sound right or too long winded?
Mattie
Post by Mattie »
that is exactly what I said to do haha
Matthew
Vynmarius
Post by Vynmarius »
Then im on the right track! do you have a better way to match the printed image and substrate up though?!
Mattie
Post by Mattie »
It's easier when the customer has text on as all u need to do it line the case insert up with the text. When it's just an image I tend to use parts of the image as reference points to line case insert or save both the complete image and the image without your template and open both in photoshop
Matthew
Vynmarius
Post by Vynmarius »
yeah I see, there must be a better way somehow, I wonder if thats how Funky pigeon do it?!
Users browsing this forum: No registered users and 12 guests
