That time of yr...new printers
Quinsfan
Re: That time of yr...new printers
Post by Quinsfan »
I have had banding a couple of times and found it to be the file size especially a jpeg. So I open it in Gimp and scale it down to reduce the file size and it then prints no problem. Not sure if this helps your situation though.
bigj2552
Post by bigj2552 »
off to try head and paper alignment
bigj2552
Post by bigj2552 »
Hmmm this does not look good for us having just bought these ricoh printers
Quinsfan
Post by Quinsfan »
Could it be non sawgrass inks with the the powerdriver? Maybe getting a profile for your inks may work.
bigj2552
Post by bigj2552 »
Quinsfan;108303 wrote:Could it be non sawgrass inks with the the powerdriver? Maybe getting a profile for your inks may work.
cant be that...as when one prints on plain paper = no banding at all...and all 4 nozzle checks are full/perfect
tried 3 idff sub papers, so it aint that either
and....
it prints out the other images fine...just not full deep red for the keep calm stuff, plus the banding only on the red/magenta
and blacks are tad lighters than for the epson prints....fact a lot lighter.....so yes, a profile might help that, but not the banding on the magenta
mags1892
Post by mags1892 »
bigj2552;107788 wrote:morning justin ;)
been a while bud...hope you well...
we dont use sawgrass inks remember - we import from asia justin - dont think one can use the likes of inktec sub inks in that printer...or am i wrong here ?
i seen diff on the 5 colour in regards to the blacks...really deep with the 5.
just wondering if the prints would be even better having 6 carts - cant go back to using 4 inks now ;)
the wee xp520 made that clear print wise ;)
i have many clients using inktec in these ;)
mags1892
Post by mags1892 »
bigj2552;108278 wrote:update...
got printers here now...
set one up....refillable carts in - gel inks in - powerdriver working great ( colours coming out as they should ) - but getting banding on prints, mainly magenta.
flushed heads, head cleaned, tried all sorts of settings, adjusting the head aliments slightly....nope:rolleyes:
nozzle checks all come out intact, no gaps.....dam odd this one
Ive had a 3110 fail nozzle check fine but banding on prints eventually ricoh replaced the printer, apparently they are having quite a few issues with this. Ive stop recomending the ricoh because of this issue so far 3 clients have issues using my inks and another two using sawgras inks. Seems there is an inherent fault with these machines.
mags1892;108312 wrote:Ive had a 3110 fail nozzle check fine but banding on prints eventually ricoh replaced the printer, apparently they are having quite a few issues with this. Ive stop recomending the ricoh because of this issue so far 3 clients have issues using my inks and another two using sawgras inks. Seems there is an inherent fault with these machines.
Can't confirm this as we are still selling a number of the SG3110s and haven't had a banding issue in a long long time. Perhaps you've had a bad batch of these but it's certainly not widespread.
bigj2552
Post by bigj2552 »
i have had it with ricoh mags.i dont have time to mess about with things like this...we are down to one printer and its affecting productivity a lot, so much so we shut amazon down till we get other printers in...
so, we decided on 2 epson 1500w printers...getting delivered on sat coming ;)..with possibility of another before summer kicks in, if things go to plan in the coming months...
have to keep one of the ricohs we bought , as we put refillable gel inks in and buggered the warranty, so i,m told :rolleyes:
will do for invoices and such
as i was saying to justin, i am totally and utterly cheesed off with things breaking down, or just not working right when we get them...and all are/were brand new products :rolleyes:
have a an unlucky start to the year....but hopefully getting these new epson 1500's will get us back on track...hopefully ! :wink:
mags1892
Post by mags1892 »
bms;108315 wrote:Can't confirm this as we are still selling a number of the SG3110s and haven't had a banding issue in a long long time. Perhaps you've had a bad batch of these but it's certainly not widespread.
Im not supplying the printers my clients buy them generally on ebay as theyre cheap
