Sublimation machine does not heat up to required temperature. HELP!!!
3D Sublimation
dorlov
Re: Sublimation machine does not heat up to required temperature. HELP!!!
Post by dorlov »
Hi everyone, my red sublimation machine is not heating up to required temperature, max to 50-60 degrees. Any ideas? I will try to replace flat battery which is under motherboard, last time it solved pump problem.
membrane
Post by membrane »
Normally a bad motherboard or blown fuse in the heating element. I've had to replace both in my machine.
