Graphtec A3 Carrier Sheet
gstk
Re: Graphtec A3 Carrier Sheet
Post by gstk »
I dont use it very often but mine is about knackered - its got about as much sticky as my tongue. Cheapest I have seen is Magictouch at £24.00 Seems a lot of money for what it is but then I am tight. Anyone know any cheaper?
Thanks in advance
NASH
Post by NASH »
i tape my vinyl to the carrier sheet at each corner and down the middle on each side, or even sometimes i don`t even use the carrier sheet.
Or try double sided tape
gstk;96680 wrote:I dont use it very often but mine is about knackered - its got about as much sticky as my tongue. Cheapest I have seen is Magictouch at £24.00 Seems a lot of money for what it is but then I am tight. Anyone know any cheaper?
Thanks in advance
Try spraying the surface with something like surface mount to get some adhension back on to the carrier sheet.
Has thanked: 11 times
I bought one off eBay a while back, not original but did the job perfectly well and a lot cheaper :-)
malfunction
Post by malfunction »
I refresh mine with a spray on repositionable adhesive, I think it's called stick and spray without checking. The Range sell it for about a fiver. just put a strip of masking tape on each side of the sheet to protect the area where the rollers run and give it a light spray.
gstk
Post by gstk »
Excellent ideas will try. Thanks guys
