can Cameo 2 work with CorelDraw 5-6 ??..
Ravisteam
Re: can Cameo 2 work with CorelDraw 5-6 ??..
Post by Ravisteam »
Hi guys .. Does anyone know how to link Cameo 2 with CorelDraw 6 ..??...Thanks in advance .
ASO Embroidery
Post by ASO Embroidery »
Hi don't have a cameo 2 but mine is just linked direct by usb and works fin. As far as I'm aware there shouldn't be much difference connection wise
Sammy
ASO Embroidery
Hi Sorry should have said I run x7 works fine for me
Sammy
KathG
Post by KathG »
Hi Ravisteam, if you want to be able to cut from CorelDraw you need to buy the plugin. It's called the Silhouette Connect Plugin.
if you go to The Yolo website and click on the Silhouette store link you will see it there.
Kath
Cheers
Kath
ASO Embroidery
Hi KathG
Not disagreeing with you about silhouette connect if you wish to cut direct from Corel to the cameo software but you can send it to the Cameo by the usual method saving the file and opening in the cameo software as you will know its just a easier and quicker method but its about £39 to buy so personally I go by the cheaper method.
Sammy
Ravisteam
Post by Ravisteam »
KathG;100650 wrote:Hi Ravisteam, if you want to be able to cut from CorelDraw you need to buy the plugin. It's called the Silhouette Connect Plugin.
Kath
Thanks for your advice ....
Ravisteam
Post by Ravisteam »
ASO Embroidery;100655 wrote:Hi KathG
Sammy
Hi ASO , So can you open Corel .crd files in Cameo software ..??. Ive seen somewhere that you cant ..!!
KathG
Post by KathG »
Hi Ravisteam, I'm not sure about the Cameo software opening .crd files, but all you would need to do is export from CorelDraw choosing to save as an SVG file, then you would import the SVG file into the Silhoutte studio software. One thing though you will need to have the Designer Edition of the Silhouette software to do this.
Kath
Cheers
Kath
ASO Embroidery
Hi Ravisteam
Yup concur with Kath that's the way I do it. And that's something I had forgot you do need the designer edition software to do it Although as Kath says its a lot easier with the connect plugin but me being a Scot I save the money LOL.
Sammy.
Ravisteam
Post by Ravisteam »
ASO Embroidery;100769 wrote:Hi Ravisteam
Sammy.
Thanks KathyG and Sammy ...Ill get the Designer edition then ...Thanks a lot again ..
