Just in case Paul is busy.
Has anybody had a profile done when using photoshop CC 2015? The instructions make sense until I go to print the swatches out.
Paul says open them in photoshop etc all fine there, but when he says print, my photoshop CC2015 looks nothing like Pauls example.
Rather bemused
Janners
Pauls ICC with Photoshop CC 2015
Re: Pauls ICC with Photoshop CC 2015
don't print your charts from Photoshop!
You need to use the Adobe Color Printer Utility to make sure you print with no colour management affecting the colours.
https://helpx.adobe.com/photoshop/kb/no ... ssing.html
Cheers Pisq.
I recalled there was something like that.
My colormunki gives a green cast on gray scale images. It appears it may be a colormunki issue. Hardly ever notice this but I have a pencil drawing to do ...and with this it's noticable.
How did you overcome your yellow cast?
Tim is right
if your photoshop is newer then CS4 then you dont have correct settings there. use this app https://www.dropbox.com/s/q6pqmcmcg7n40zg/ACPU.zip?dl=0
rest of the settings remain the same
