newbie problems
Johnellisimages
Re: newbie problems
Post by Johnellisimages »
I Hi, I've just tried printing photos onto mugs for the first time. The results were patchy with brown / yellow results and not very clear. I've checked I'm printing on the right side of the paper. First mug was 180-180 then I tried a bit hotter 200. I loosened and tightened the press. After 6 attempts I'm thought I'd best see if someone can help. I'm using tru pix paper with Inktec subli nova ink, windsor blanks orca coated from Subli and a blue press not sure of the make. Am I over cooking them? Any helps appreciated
mags1892
Re: newbie problems
Post by mags1892 »
I Use a similar setup with xpres paper 140 seconds 170 degrees with sublinova smart works a treat what profile are you using ? You may find youre using too high a temp and too long.
Johnellisimages
Re: newbie problems
mags1892;104450 wrote:I Use a similar setup with xpres paper 140 seconds 170 degrees with sublinova smart works a treat what profile are you using ? You may find youre using too high a temp and too long.
I'm using the Epson workforce 5110 with the 4095 profile. Colours printed out look fine, probably too hot will see how shorter pressing at lower temp does.
Thanks for your help
