Ricoh SG3110dn Printer Settings
laberge86
Re: Ricoh SG3110dn Printer Settings
Post by laberge86 »
Hi, I wonder if anyone can help me.
I'm trying to figure out what is the best settings are for this printer when printing onto sublimation paper.
it seems everything i do either doesn't work or the image doesn't seem to transfer.
if anyone has any suggestions, that would be helpful
thanks
laberge86;114777 wrote:Hi, I wonder if anyone can help me.
thanks
With PowerDriver installed just keep the default settings and don't change anything. The image will
mirror automatically and the default will be fine for getting started or you may decide just to keep using this setting. Remember to select PowerDriver as the printer not the Ricoh printer driver.
Of course the above assumes you've got sublimation ink in your printer and not the Ricoh inks. The cartridges should have SubliJetR written on each one of them.
