DAE HA UK / Garment films UK any good?
windyash
Re: DAE HA UK / Garment films UK any good?
Post by windyash »
Has anyone tried this brand of vinyl supplied by Garment Films Uk?
Prices look good and good range of materials and colours.
Thought I would check before I had a go with them
Mimaki CG60-st cutter , Ricoh 3110 sub printer , OKi laser , Epson inkjet , 2x heat press , mug press , cap press, Flexisign pro and coreldraw X6..............and learning ...........
and now a Roland SP-300v Versacamm !!!!!!
mr-gobby
Post by mr-gobby »
Not tried them so be interested to hear anyone's views especially on the printables.
Andysam26467
Post by Andysam26467 »
I use them all the time. They are great to work with and weed easily.
The only problems I've had with them is the vinyl separating from the backing forming air bubbles if not stored correctly (mainly off cuts)
The glitter range is fantastic.
Andy
Rob Adcock
Post by Rob Adcock »
i have used them for a couple of years now in fact dont use anything els, the glitters are fantastic
RogerC
Post by RogerC »
Glitter is brilliant looking, we use it on 'T's and bags but initially it was a 'barsteward' to cut(Graphtec 5000-60).....eventually found pressure of 25 and 3 cuts does the trick.
windyash
Post by windyash »
Thanks for the replies, just ordered some to give it a go
mags1892
Post by mags1892 »
its good stuff korean manufacturer one of my client only used this for some high end stuff that was actually on show at the olympics , swears by it ;)
Salty
Post by Salty »
we've had good experiences with Dae Ha - were having proiblems weeding MDP's Hotmark Glitter so tried Dae Ha's and havent looked back - their Stretch Metallic is great too - try and get to Print&Promotion Live at the NEC last weekend in Jan where they will be exhibiting and pick up some samples - can defo recommend - good prices too :cool:
leedjc
Post by leedjc »
I'm fairly sure that DAE HA supply some of the Ralawise vinyl - the glitter particularly seems exactly the same.
milspectees
Post by milspectees »
leedjc;130003 wrote:I'm fairly sure that DAE HA supply some of the Ralawise vinyl - the glitter particularly seems exactly the same.
They say the don't supply to Ralawise. Most of the Ralawise vinyl is supplied by Magic Touch. The Dae Ha stuff, especially the reflective and effects stuff is way way better
