Help needed pls
3D Sublimation
lynnie1962
Re: Help needed pls
Post by lynnie1962 »
I have a little experience in sub printing on ceramics and mdf etc. Can't seem to manage fabrics with much success. Has anyone got any tips for temp and time pls.😊?
Sent from my SM-G900F using Tapatalk
Quinsfan
Re: Help needed pls
Post by Quinsfan »
What material is the fabric? What printer and inks are you using? Sublimation will only work on a polyester garment or one with a high % of polyester
lynnie1962
Re: Help needed pls
I have bought sublimation pillow cases. The recommended temp is 190 degrees. But my press only goes down to 200. Not sure of the timing either as I get scorching. Can you advise?
lynnie1962
Re: Help needed pls
I am using an epson printer and sub inks
Quinsfan
Re: Help needed pls
Post by Quinsfan »
What press are you using as most sublimation is at 180-190 and normally start at 0 and go up as you can use them for Tshirt vinyl which presses at lower temperatures
lynnie1962
Re: Help needed pls
lynnie1962
Re: Help needed pls
It is an 8 in one. I do mdf and phone cases magic on it but struggling with polyester products
Quinsfan
Re: Help needed pls
Post by Quinsfan »
Could the temps be in Fahrenheit
Quinsfan
Re: Help needed pls
Post by Quinsfan »
Sorry hit send as 200 Fahrenheit is only about 90 Celsius
lynnie1962
Re: Help needed pls
I thought this too.
