Hi all.
Just wondered if anyone is currently using Multi-Trans?
We got a few samples to test as we need something to go on glass. I've been testing on a bog standard black Samsung laser to see if would work for us, then we can get an OKI if it works out.
The results haven't been great as the print seems to scratch off quite easily! Not sure if it's the laser I'm using or just the settings etc. Have tested different timings, pressure, curing afterward etc.
Anyone using it on glass with success? and can give some advice.
Also looking to purchase a few sheets printed with an OKI White to test if anyone can help.
Anyone using Forever Multi-Trans ?
blackadder
Re: Anyone using Forever Multi-Trans ?
I've just started with it on some mugs. and it seems to be working pretty good.
Can't scratch it off but I am having some issues which I think is probably pressure not set correctly
the reason it scratches off is because the toner isn't fusing properly.
Need to use on heaviest card setting.
it's the reason Oki is popular, - straight paper path and Extra heavy card setting.
Toner needs much longer in the fuser to bond properly.
Beware, some transfer papers can trash incompatible laser printers ....
