Hello guys!
I am after some domed stickers for sublimation cufflinks. I like the product but i feel like sticked metal insert doesnt make it quite finished yet. so I woud like to ad some domed sticker. I will appreciate any links.
all the best
domed Cufflinks
- Forgetful8
Re: domed Cufflinks
I've seen this kit advertised on MDP Supplies: http://www.mdpsupplies.co.uk/doming.asp
I was almost tempted - but my partner said no...something about me being childish and doming anything and everything (I'm not going to deny it...I probably would :biggrin:)
[CENTER]A bored sailor is a mischievous sailor...
Boy, am I bored![/CENTER]
Re: domed Cufflinks
Get in touch with Mark or Eddie, they know all about doming
INTERFAX ACUFLOW LTD.
UNIT 2b, REDDICAP HEATH ROAD
SUTTON COLDFIELD
WEST MIDLANDS
B75 7DU
PHONE: 0121 378 2289
SUTTON COLDFIELD
WEST MIDLANDS
B75 7DU
Code: Select all
[URL]http://shop.acuflow.co.uk/[/url]Re: domed Cufflinks
You don't need to make them, they're called cabochons and can be sourced from jewellery suppliers - available in resiny rubber type stuff, or hard acrylic and glass
Some are already supplied with an adhesive layer, others you need to use glue with.
Re: domed Cufflinks
Sublimetals and KYD Products both sell adhesive domes for this sort of thing.
Customprintwales
Re: domed Cufflinks
Don't buy too many in one go if you've not used them before.
I was a bit disappointed when I first used them. The dome looks nice but it does make the print look a little dirty. The dome can also show up the adhesive marks on the underside and minor imperfections only show up once you've fitted them to the cufflink.
While domes give a classic look to the cufflink have plain metal gives a more modern and crisp look.
But I guess it depends on the market you aim for.
Re: domed Cufflinks
thanks guys! i will look in to links and see where I can get small moq and check them out.
