Changing ink supplier
The gza
Re: Changing ink supplier
Post by The gza »
Hi guys i am currently using sublimation ink from cityinkexpress in a Ricoh printer and a Mac, I wanted to know if I change ink say to sublinova do I need to get another icc profile made up?
And if anyone has one what your opinions in comparison off the 2.
Hi. I use CIE inks and paper with a profile supplied by them and get great results. If you were to change inks you'd need a new profile to match the new inks and you'd also need to flush out your old inks. Remember that refilling with the new inks will use up quite a bit of them just to fill the printer's ink lines.
The gza
Post by The gza »
great thankyou for your help.
Users browsing this forum: Amazon [Bot] and 7 guests
