Epson 1500w printing lines - help!
MissRecord
Re: Epson 1500w printing lines - help!
Post by MissRecord »
I’ve installed CisS ink system for the second time and after a week
There are now lines horizontally appearing on the print out.
i am trying to mug sublimate my pet portraits and getting a bit frustrated!
also some extra black ink residue after some lettering. Like it’s on the rollers?
Any advise most welcome!
Do I need a new printer? Ricoh?
Post by GoonerGary »
Did you do a printer head alignment test when you installed the CISS? Have you cleaned the rollers and all areas inside the printer for excess ink build up?
MissRecord
How do I clean the rollers? Is there a video or anything that would show me?
You can buy A4 cleaning sheets, but if you are careful, you can wipe a small amount of IPA (isopropyl alcohol) onto a sheet of sublimation paper and run it through the printer. Get a J cloth with a touch of IPA and clean all inside the printer where sludge builds up.
MissRecord
GoonerGary;137243 wrote:You can buy A4 cleaning sheets, but if you are careful, you can wipe a small amount of IPA (isopropyl alcohol) onto a sheet of sublimation paper and run it through the printer. Get a J cloth with a touch of IPA and clean all inside the printer where sludge builds up.
i just tried to clean inside but now it’s not printing any ink?!
What should I do? Sorry complete novice.
annie
It's difficult to help without seeing what's wrong. Cleaning, head alignment, priming the cartridge, head cleans & nozzle checks are the only things you can do without more serious work. Some YouTube videos can give demonstrations which may help you better.
Has thanked: 11 times
Be careful not to do more than a couple of head cleans without leaving the printer to rest. Can you post any photos to help us see the issues? Are you getting any nozzle check print at all?
Where inside did you try to clean and what with?
