ICC profile creation
rabb
Re: ICC profile creation
Post by rabb »
I don't have a particular issue with the quality of my prints but where do you guys go to for quality ICC profiles?
If I was to replace my printers tomorrow, where would you recommend I got a good custom ICC made for use with a mac?
Thanks in advance :)
If you want to do this seriously, then buy your own profiling kit, then you can make profiles for the different product types/substrates you print - this will give you much better results than using one profile for everything.
rabb
Post by rabb »
OK, I've bought a colormunki Photo. That should allow me to calibrate both my iMAC display and my printers for each product individually.
JMugs
Has thanked: 9 times
Post by JMugs »
I have had a colormunki for the last 5 years. Easy to use, good results.
Janners
We use a Datacolor Spyder system for monitors and printers - same kinda thing as the ColorMunki but uses a different scanner for the printer compared to the screens.
