Microtec COS-10B Digital Touch Panel Mug Press
REDQUASAR
Re: Microtec COS-10B Digital Touch Panel Mug Press
Post by REDQUASAR »
Hi, does anyone have an instruction manual for, or know how to operate, a Microtec COS-10B Digital Touch Panel Mug Press?
Daninho
Post by Daninho »
Well, it works just like every other mug press wih the difference that it stinks like hell, it has a very aggressive chemical odor when heated up. Its a mug press that starts the countdown as soon as you clamp a mug in unlike some other presses, those will start the countdown when the target temperature of the mug is reached. Its very simple to use, wih the screw behind the black rubber ball you can adjust the pressure. I dont like mine because it produced strange lines in dark colors, i guess its because of the heating tubes, so if you look closely to the sublimated mug you can see the heating tube lines, never figured out how i can solve that issue, thats whyi use an oven now
REDQUASAR
Post by REDQUASAR »
Hi, thanks for your response, and sorry for the late reply. I've been away. So, it works a bit like an Adkins, in that it starts the countdown once the mug is clamped? Very posh! If you get time, could you tell me how to set the time and temperature. That would be a great help if you could. Thanks, Mick
