Hi,
I am having a weird issue with the Omega Series 750 Heat Press and I hope someone here can help. When I turn on the press and the compressor, the air starts to coming of the bottom of the pressure controls on the press. I have left it for 6 mins and nothing happens just continuous air coming out from the bottom. The thing I noticed is that if I plug the hole for 1.30 mins the pressure goes up and once past the 0.4 mark the air stops rushing out from the bottom and the press starts to work like normal. Does anyone have any ideas why this is and what I can do to fix it?
I have contacted Aadkins but thus far have got no response.
Any help would be much appreciated.
Kind regards,
Aadkins Omega Series 750 issue
- UK Printed Mugs
Re: Aadkins Omega Series 750 issue
Hi. Defo one for Steve at Aadkins. Just keep trying as it is only Steve who will be able to help you.
ask Steve @ Adkins !
bubbleimages
We are also awaiting a customer service request from Adkins, so presume they are snowed under at the moment.
