Flat Bed Heat Press
Scott
Re: Flat Bed Heat Press
Post by Scott »
Good Morning All
i'm looking for a heat press as a back up for my adkins beta maxi,
it has started blowing fuses in the plug
We mainly print 2mm thick frp and the rock photo slates, ( so needs to be able to adjust pressure to this thickness )
i don't want to spend a fortune as will only be used now and again
Any Suggestions would be greatly appreciated
Many Thanks.
Scott
If yo u want another decent press sticking with the Adkins, this looks like a good buy. It's the older style and is better put together. Newer Chinese built presses have the darker grey upper platen. Whilst these were part sourced in China they were assembled in the UK.
https://www.ebay.co.uk/itm/115710013079 ... R_T11Y_YYQ
