Can anyone do Rhinestones?
AdamB
Re: Can anyone do Rhinestones?
Post by AdamB »
Hi all,
I'm looking for someone who can do rhinestones that can supply me with them ready to press.
I need to make 4 t-shirts which have a rhinestone effect on them as one of the letters. The rhinestone design measures 80mm by 80mm.
If anyone can help please PM me with your price - colours are still to be confirmed but all stones in each design will be of the same colour.
Adam
Hi Adam! price depend from size of designe as it need to be known how many stones will be used
have you got designe yet???
AdamB
Post by AdamB »
Paul;23250 wrote:Hi Adam! price depend from size of designe as it need to be known how many stones will be used
Yes Paul - I have an image of what's required and also the size specifications - the only thing to be confirmed is the colour of stone required (and I will then match that colour of stone with t-shirt vinyl).
Can you do them Paul?
can you pm me designe please? so I can tell you if I can do it or not.
PAul
AdamB
Post by AdamB »
Paul;23252 wrote:can you pm me designe please? so I can tell you if I can do it or not.
PAul
PM Sent mate :-)
thanks mate! quite simple designe. have you got it ready as a template? as this is most tricky part :)
AdamB
Post by AdamB »
Paul, excuse my ignorance but what do you need to create something like the link I sent you? If it's just a graphic - measuring the size I require then no problem.
If I need to convert something into a rhineshtone format (if there is such a thing?) then I don't know what software is required to do that.
If it is just the graphic you need then can you PM me the cost of a design? I now know that 3 of the designs will be in Pink - I'm waiting on confirmation of the forth but if you have a cost then it will let me push this a little more with the customer.
Many thanks mate
Adam
AdamB
Post by AdamB »
The other question I must ask is will the designs be ok travelling in the post?
graphic need to be in vector. lines. then you convert it to the correct size dots for cuter to cut the holes.
but i already know that i dont have pink :( but i got loads of gold ;) 3mm.
AdamB
Post by AdamB »
Paul;23257 wrote:graphic need to be in vector. lines. then you convert it to the correct size dots for cuter to cut the holes.
Ok .................... if they agreed to have the rhinestone design in Gold, how much for 4 designs for the specifications that I gave you?
