Ricoh 3300 Is printing blank!
TailoreChocs
Re: Ricoh 3300 Is printing blank!
Post by TailoreChocs »
Hi Guys.. I've installed new ink cartridges to see if that was the reason as ink was low but it's going through the motions, sounds as if its printing but I end up with a blank page! Any ideas welcome..
I wouldn't have thought it was ink as the tubes are long from the cartridges to the printhead so it's very unlikely the cartridges would be empty and the tubes also empty. Have you cleaned or flushed the printhead or done a nozzle check?
